Newbie help.....joining two split elements together....
1
1964deano
Guys i am trying (and failing ) to simply join elements together so i can produce a closed profile. The closed profile relies on having the end points connected; this is where it all falls apart for me........couldnt be any easier, could it ?:mad:
Trim Corner command to join elements.
Hi Deano,
I suppose you're trying to join the elements in a 2D sketch?
If so, you can use the 'Trim Corner' command to accomplish your task.
Simply select the elements to form a closed profile and they'll move and join at the intersection point.
Hope this helps solve your problem. :)
