I am trying to do a surface offset of a thin wall panel. but some of the faces will not work, with a "The result cannot be assembled because of a current or permanent restriction .... Change value or modify input body" message. This shown in the pdf ... the faces/areas on the part which will not offset are in blue. Also, how do you select all of the facets of a face of a part in one go in CATIA?
