placing hole in assembly
support
When I place a hole in an assembly, it doesn't show up in the individual parts. I know it should, but apparently I'm doing something wrong. What??:-D
We found a response to your question!
Courtesy of: Autodesk Inventor Groups at http://discussion.autodesk.com/
responded to by: Kent Keller
Assembly features aren't currently able to be pushed down the the part
level. Assembly features are generally used for machining type of
operations on weldments.
Kent Keller
Autodesk Discussion Group Facilitator
Thanks for using the Q&A Board!
We found another response to your question!
Courtesy of Autodesk Inventor Groups at http://discussion.autodesk.com/
Reply From: just havin a ball
Date: Dec/28/05 - 04:07 (GMT)
Re: Placing hole in assembly
> ... I know it should, but ...
Base on? `;^)
support said:
Assembly features aren't currently able to be pushed down the the part level. Assembly features are generally used for machining type of
Reply From: Andy Palioca \(Autodesk, Inc.\)
Date: Jan/02/06 - 01:12 (CST)
One exception are the holes created with Bolted Connections (Design
Accelerator). The holes created with the fastener set are pushed to the
part level.
-- Andy Palioca
(Autodesk, Inc.)
3DCADTips Support Desk :cool:
