OliverMonson
I started working in CATIA v5 and have the issue: after scanning small objects and slightly processing them in Artec Studio, I export 3D models in Catia and get the problem with solid textures. After any operation with model (for example transfer, rotation, scaling, etc) it becomes transparent and this transparency can not be removed by usual methods. It appears with solid textures only, everything is normal with surfaces. It doesn't affect the model itself, but when I need to make screenshots to show the customer a model - it becomes a big problem.
Modifying the model parameter removes transparency. For example, if I increase the diameter of the model by 1 mm, the transparency disappears, then I need to open the model again and change the diameter to its original value.
Have anyone faced something similar already? Thank you in advance.
P.S. cat_vbo_allowed disabled
