Reference dimensions in Drafting
el-mariachi
(note: I am only a week into using Catia)
I have looked through every tool bar and properties and I cannot find where to change a dimension to reference other than manually adding parenthesis in front and after the dimension
There has to be a better/easier way
As you use CATIA more and more you will learn how great and powerful it is as a 3D modeler and yet how weak CATIA V5 is for drafting
CATIA V5 has no capability to make a dimension reference - you have to type in a parenthesis before and after the value.
I've noticed some users have a little macro that will add the parenthesis. If I can find it, I'll add something to this thread.
el-mariachi
As you use CATIA more and more you will learn how great and powerful it is as a 3D modeler and yet how weak it is for drafting
I am starting to see what you mean about the drafting
I found the macro program. Jus copy&paste the code below into a new macro on your system:
Sub CATMain()
Dim MySel As Selection
Set MySel = CATIA.ActiveDocument.Selection
Dim MyDim As DrawingDimension
Dim Array1 As String
Dim Array2 As String
Dim Array3 As String
Dim Array4 As String
For i = 1 To MySel.Count
If TypeName(MySel.Item(i).Value) = "DrawingDimension" Then
Set MyDim = MySel.Item(i).Value
MyDim.GetValue.GetBaultText 1,Array1,Array2,Array3,Array4
MyDim.GetValue.SetBaultText 1, "(", ")",Array3,Array4
End If
Next
End Sub
The code above was written by Fernando.
https://www.eng-tips.com/viewthread.cfm?qid=328045
el-mariachi
Sub CATMain()
End If
Next
End Sub
Great thank you!
