save as .pdf
Script to do create PDF and DWG
Create a textfile with extensions .CATvbs
Paste all below line into thetextfile.CATvbs and in Catia run this macro.
This macro create both PDF and DWG at same time.
Language="VBSCRIPT"
Sub CATMain()
Dim oFSO
Set oFSO= CreateObject("Scripting.FileSystemObject")
PathToCATFiles = InputBox("Enter path there CATDrawings-files exist" & vbCrLf, "File", "")
strComputer = "."
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
If Not oFSO.FolderExists(PathToCATFiles& "\PDF") Then
oFSO.CreateFolder(PathToCATFiles& "\PDF")
End If
If Not oFSO.FolderExists(PathToCATFiles& "\DWG") Then
oFSO.CreateFolder(PathToCATFiles& "\DWG")
End If
Set FileList = objWMIService.ExecQuery("Associators of {Win32_Directory.Name='" & PathToCATFiles & "'} Where " & "ResultClass = CIM_DataFile")
For Each objFile In FileList
If objFile.Extension = "CATDrawing" Then
On Error Resume next
Set documents = CATIA.Documents
Set drawingDocument = documents.Open(PathToCATFiles & "\" & objFile.FileName & "." & objFile.Extension)
Set drawingDocument = CATIA.ActiveDocument
drawingDocument.ExportData PathToCATFiles & "\PDF\" & objFile.FileName & ".pdf", "pdf"
drawingDocument.ExportData PathToCATFiles & "\DWG\" & objFile.FileName & ".dwg", "dwg"
Set specsAndGeomWindow = CATIA.ActiveWindow
specsAndGeomWindow.Close
drawingDocument.Close
End If
Next
Wscript.Echo "DWG and PDF files created in subfolders to " & PathToCATFiles
End Sub
