simple question: where exactly is transparency feature in SW
Per
I just want to make some parts transparent so I can visualize my assembly better, but I haven't been able to find the 'slider' under Tools>options>colors or using the Help feature in SW 2009 student.
Right click on the part in the assembly and select "Change transparency"
OR
Right click on the part, select "appearances", select if you want to set at part or assembly level, then in the appearance property manager, set the transparency level
If you right click on the part or assembly in either the design area or design tree, an option is there called 'Change Transparency' this is a semi transparent tool.
Or
Select the part or assembly, click the coloured ball type object at the top of the design area, then select a clear plastic from the right hand side appearances.
Hope this helps
CAD MAN
Right click part or assembly in the design area or design tree and select 'change transparency'.
CAD MAN
