Hi Community,
I am currently studying Aeronautical and Mechanical Engineering in Wales, UK. My final year project is about a compact machine which is able to impregnate carbon fibres. This should happens through the Siphon impregnation. The fibres and the resin go through a tube which is sinusoidal. Due to the tension on both sides the fibre is pressed through the epoxy resin at the curves.
I already worked with Catia therefore I would like to simulate the process in Catia. Is it possible to do this with Catia? I would like to see the fibre/matrix ratio after the process. If it is not possible with Catia do you know any other programms which are able to do this?
Best wishes
Matthias
Best wishes
Matthias
