Sketcher toolbar shows text instead of icons options
Fedce
I am new to Catia and while learning I noticed this difference with what I think should be the "standard" visualization of options in the second part of the sketchers toolbar (called switch bar?): I have text options instead of icons, and this make a giant toolbar, not so smart to use.
As attachments there's how it looks if I select the "corner" command, and also the simple rectangle command.
I already tried with tools>customize>toolbars>restore and with tools>customize>options. I noticed I can see a lot of command icons inside tools>customize>commands and selecting "all commands" in the left window, but the icons I need are missing in the right-side list.
I can't find it out in previous threads, can you help me?
What could be this due to? How can I fix it?
Thank you
You are right, Federico. You should see icons in all the toolbars, instead of the command names.
I'm not sure what is causing this as I've never seen this before. Try using Tools + Options + General and selecting the icon (text?) in the lower-left corner to reset all pages back to default settings.
If that doesn't work, you might have to re-install CATIA.
Did CATIA always look this way on your computer? Did you do anything recently that might have caused this? Which release of CATIA are you running?
