Surfaces to Solid
Raxn
In ProE Wildfire, is there any method to sew or stitch a set of surfaces together, that enclose a volume, to create a solid. Thanks in advance.
design-engine
in wildfire 4.0 you can select all the surfaces and merge at once. Once the surfaces are merged you can then use the 'solidify' function to solidify the geometry. The group of surfaces will need to as we say 'hold water' or be a water tight merge.
Good luck.
