In Part/Sketch environment always when i create a text (to emboss it for example) the orientation text option is always disable. Why? In drawing environment the same tool works well. Any suggestions?
Thanks in advance.
The Text Editor is used in many places through out the product (Drawing Manager most predominantly). One option, yes, is to simply hid the controls that aren't being used, but in the case of the text editor, that would mean a lot of empty Grey space depending on the command. If you find it difficult to control text rotation with constraints, remember you can always use the sketch rotate command.
