Thick surface: current offset value leads to a local degeneration on a surface
Micho
Hi. I couldn't find the answer here. To cut it short. I get this error:
(if I follow the instruction it does work, but I need the thickness to be 20 mm)
everytime I try to make thick surface of this (Multi-section between 3 splines):
Offset does not work neither:
It seems there is a problem with the highlighted part of the surface. Anybody knows how to fix this?
Surface modeling is not easy. It takes a lot of detailed effort to get smooth flowing curves and surfaces with good continuity.
May I suggest a different approach for the canopy: Redraw the sections as closed profiles with the outside curve and an offset (20mm) inside curve. Instead of a Multi-Section Surface, use a Multi-Section Solid.
Micho
Actually, surfaces of the canopy were not as ideal as I had thought. Fixing this did the job, but I will keep in mind Your advice :) Thank You
