Thread
amnon
Hej,
I have a shaft with Metric Thick Pitch, and when I change shaft diameter I lost Laterar Face all the time. Is there any way the Laterar face following shaft diameter.
Best Regards
Amnon
Amnon,
As you know, by changing the diameter of the Shaft/Hole, the Thread size must also be changed to match.
You could use the Hole command to add a threaded hole in one step.
But, I don't know anyway to do external threads in one step (without a Macro or Powercopy). It would be nice to specify a thread size, and have the Shaft automatically sized.
You could setup a formula; the Thread Diameter = shaft diameter
After trying different options, I did notice that re-selecting the Thread Type would automatically change the thread size when I had the exact shaft diameter.
amnon
I did forula the Thread Diameter = shaft diameter, but the problem is that thread diameter do not recognize thread surface
