K
kudos306
1) How do you measure min & max distances between curves and surfaces with
knowledge fusion and use them further in calculations.
2) What is the syntax for ug_part_family (if an example is available it will be
highly helpful).
3) How to carry out automatic part substitution using KF.
4) How to perform checking of surfaces (examine geometry) using KF.
Can these surfaces be autocorrected?
5) Is it possible to check whether a solid body is present at a certain location
and if it is not then change position of a hole, boss etc.?
highly helpful).
