Unable to close the profile and creating sliding roll
elreedy
Hey guys, i am unable to create closed profile to slide the roll. due to the black dots. i believe it is open profile. I have tried to close it but failed.
Any advice
Where is the profile? And how are you trying to close it? What error do you get?
I see 3 "tracks" in the picture (outer, middle, and inner). Have you joined each track to form 3 continuous curves?
elreedy
Thanks MrCATIA for your reply. I`m not professional enough to understand and answer your question (Have you joined each track to form 3 continuous curves?). appreciate if you make it more clear for me.
I`m trying to create movement (slide roll) but the cylinder stop rolling on the black dots and continuous to rotate on the track. i guess the reason is the black dot.
I did another example and made the track like a closed circles and no dots appeared then the roller was able to rotate on the track.
Appreciate your advice
I think the black dots represent the end points of the lines and circles that make up the track. (like you said earlier; it's on open profile - a non-continuous track)
To have a continuous track, you should use the Join command and select the lines and circles to combine them into a single curve.
Just like your circle example, you can now use the Join curve with your Sliding Roll joint.
