Hello, my friends
I've been trying to create a part like the one shown in Pad1 picture.
The only constraints I have are the distance between the pad base to the hole center (40mm) and the vertical edge (20mm). So, the hole center coordinates are (40, 20). The top circle is not dimensionally defined but is concentric to the hole center.
When editing sketch 1 it seems I can't use Point 1 from sketch 2 to define the circle in sketch 1 (I can't project it and I can't find a way to make it always visible when editing sketch 1). Obviously I could create a point in sketch 1 coincident with the hole center but it doesn't seem the best solution. Any sugestions?
Thank you.
Thank you.
