I used generate dimensions command to convert scketch datas into drafting. And the dimensions apeeared green on draft. I cant change its color to black. How can i do it? Thanks so much.
Shortcut
Try this go to your tools options drafting,dimensions,Analysis display mode and make sure it is de-activated. If you check the types and colors the default for dimensions generated by 3D constraints is light green. Not sure that this is your problem but it is worth a shot.
