A
acat
Did anyone decide to shift from AUTOCAD to PRo/ENGINEER? Do you recommend to buy AUTOCAD or Pro/Engineer?
There is no simple answer to this question. Both have areas of strength and of weakness. Your decision should be driven by your goals for the software. To be honest no one package Will meet all of your needs completely so you have to choose the one that meets them the best. What kind of work are you planning to do with the software?Did anyone decide to shift from AUTOCAD to PRo/ENGINEER? Do you recommend to buy AUTOCAD or Pro/Engineer?
In my opinion,if your work is mainly on 2D,select AutoCAD,if 3D,ProE.Did anyone decide to shift from AUTOCAD to PRo/ENGINEER? Do you recommend to buy AUTOCAD or Pro/Engineer?
