Automatic Layer Setting
B
Barto
I was able to set the layer in R14 with a macro, but I am unable to do the same in AutoCAD 2000. Can some help me in this matter.
With regards,
Barto.
Hussain
Here cut and past this into the macro area of your button
^C^C-layer s DIM; ;_dimlinear
you should keep the two spaces between the ;; because they also emulate the enter command.
The only problem with this is if the dim layer is not there then it cannot set it current.
I hope this helps you.
Cheers!!!
