I fairly new in CATIA macros. I am writing a macro to create multiple holes in CATIA. The macro should work the following way:
1) RivetLines are created in a Geometrical set
2) The Macro should create holes by selecting the RivetLines and a surface.
The problem is that the RivetLines have different Coordinates and I am not able to get their positions with the code. Below is a draft of what I have done.
Please help!
Sub CATMain()
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Item("Part1.CATPart")
Set part1 = partDocument1.Part
Set shapeFactory1 = part1.ShapeFactory
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("PartBody")
Set shapes1 = body1.Shapes
Set pad1 = shapes1.Item("Pad.1")
Dim I As Integer
Dim j As Integer
For I = 1 To 10
For j = 1 To 10
Set referencej = part1.CreateReferenceFromBRepName("FSurFaceBrpPad.1;2);None);Cf11));WithTemporaryBody;WithoutBuildError;WithInitialFeatureSupport;MonoFond;MFBRepVersion_CXR15)", pad1)
Set holei = shapeFactory1.AddNewHoleFromPoint(12.7, 8.355, 51.633, referencej, 10#)
holei.Type = catSimpleHole
holei.AnchorMode = catExtremPointHoleAnchor
holei.BottomType = catFlatHoleBottom
Set limiti = holei.BottomLimit
limiti.LimitMode = catOffsetLimit
Set lengthi = holei.Diameter
lengthi.Value = 10#
Set hybridBodies1 = part1.HybridBodies
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.2")
Set hybridShapes1 = hybridBody1.HybridShapes
Set hybridShapeLineNormal1 = hybridShapes1.Item("RivetLine.i")
Set referencej = part1.CreateReferenceFromObject(hybridShapeLineNormal1)
holei.SetDirection referencej
holei.ThreadingMode = catSmoothHoleThreading
holei.ThreadSide = catRightThreadSide
lengthi.Value = 6.35
Exit For
Exit For
Next
Next
part1.Update
End Sub
Please help!
Sub CATMain()
Dim I As Integer
Dim j As Integer
For I = 1 To 10
For j = 1 To 10
lengthi.Value = 10#
Exit For
Exit For
Next
Next
part1.Update
End Sub
