constraining nightmare
spider007
in the picture below, two purple blocks in product 2 are constrained only with the offset in between them. I constrained the other two blocks (part 3's) to each purple block.
Now theoretically, you could create a parallel constraint on the top of the two white blocks, and straiten out the purple once.
BUT IT'S NOT WORKING THAT WAY.
what am I doing wrong.
I also attached a zip file with the blocks in question.
  • constrains.zip
caddict
SPIDER007
First select Product two then use the Flexible/Rigid Sub-Assembly.Then apply your constrains to achieve your required results.
