heepofajeep
I use part size, projected surface area, and mass to calculate plastic part costs;
Is there a way to make a custom script that outputs an Excel file the following, for each part in an assembly:
Projected Surface area based on "PROJ_DTM"
Volume
Width based on custom WIDTH parameter.
Height based on custom HEIGHT parameter.
Depth based on custom DEPTH parameter.
Volume & Projected Surface area are the most critical... Height/width/depth are not as important.
Thanks!
Volume
Thanks!
