*Desperate help for using spline! HELP NEEDED!*
reulim456
Hi guys I am a student learning how to use a spline for a wing tip. I was given coordinates by my lecturer. I created the points and tried using spline. However, it says two successive points are geometrically identical. However, i checked and rechecked that my points did not overlap each other. Attached are the images for your reference. Really in need of your expertise.
aymuzlhWEj
If you're sure the data is good, maybe you accidentally selected the same point twice when building the spline? Double-click on the spline to edit it, and double-check the points in the Spline Definition.
Are you adding the spline in a Sketch, or on a Working Support, or in 3D space? (I can't see the pictures - probably my employer has them blocked)
I got it, thanks a lot!!! got the coordinates wrong.
