dimension gets 25,4 times bigger when converted to dwg
nettenler
In catpart, diameter is 10 mm
In catdrawing diameter is 10 mm...
but when catdrawing converted to dwg, diameter gets 25,4 times bigger.
why?
how could i solve thi
Sounds like there's some kind of inch-to-millimeter conversion happening there.
Check your Tools + Options + Compatibility and the DXF options page:
What is your Unit of the File set to? Mine is set to Automatic, but Millimeter would probably work for you.
If that doesn't work, change the Unit to "Scale Factor" and "1 : 25.4" to reverse the conversion.
