dimension?
M
minhkhai
When I write dimension for 2D, symbols such as radius (R) or diameter, don't appear clearly. Beside, text size of Specification Tree and text size of Option are larger than normal. Please help me to edit them. Thank you very much!
M
Makinist
can you write more clearly or can u add some pictures?
you said dont appear clearly. But where on screen or printed paper?
:confused:
M
minhkhai
Sory. Now, I posts some pictures!
Minhkhai,
I've never seen an option to change the display of sketch constraints (what you called "2D dimensions"). I'm thinking it might be either your graphics card, or maybe your computer settings. Try going to the Control Panel and Display Properties and change the Screen Resolution.
You can interactively change the size of the text in the Spec Tree: click the axis in the lower-right corner (this makes the tree active), zoom the tree to whatever size you want, and click the axis again to deactivate the tree.
hope that helps :)
harsen
I think that your graphic card is bad, or, my second opinion is maybe your instalation of Catia, witch version are you using? what kind of graphic card do you have?
H
helio.b.teixeira
Deactivate "Cleartype" font. On "Control panel"-"Visualization"-"Aspect"-"Effects".
Hope it helps!!
M
minhkhai
Thanks for all your helps. I have edited size of the text in Spec tree and "Propertive" but I haven't edited symbols of dimension yet.
M
Makinist
İf yor graphic card is bad updating driver may solve yor problem but i am not sure:rolleyes:
I have the same problem
Minhkhai,
hope that helps :)
Did you corect it ? How please send an answer at sberbinschi_at_ugal.ro or post here to forum.
