Dimensional consrtraint - Configurations
b_mohan_rao
(Image attached)
In SW2007 I need to create 2 configurations.
I need the cut-extrude feature distance as follows :
Config 1 - I need the dimension A, say, 2"
Config 2 - I need dimension A = 0 (Zero)
Basically, in the sketch I am trying to have value 0 and value 2 for that perticular dimension.
Any suggestions are appriciated.
Thank you
BMR
  • question.doc
myladin
I believe you want to do this in your "Configuration Manager". You would first create the configuration at 2" and then create the same configuration at 0" or vertical above the Origin. In the 2" configuration you would supress the "0" Cut Extrude" and in the 0" Configuration you would supress the "2" Cut Extrude"
fcsuper
(Image attached)
Thank you
BMR
In addition to the other comment, I don't believe you can have a value of zero for a dimension. Why would you dim something to zero? That would mean it's a non-existant feature. Can you provide further details?
