E
Eureka
Is it possible to show midpoints,endpoints,etc on display while working in ACAD-Mechanical ?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Stewyc said:So you would like to see the mid and end point of every line in your drawing all the time? I'm assuming you have used grip edit but you want it on permanently (Grips put small boxes around the Mid & End Points when you have selected the item without a command running)? What version of MDT are you running?
