» » This is pretty easy to do.
» » 1. create a drawing with the 2d views you want
» » 2. saveas dxf or dwg's are smaller
» The program I am trying to import into is a 3d program for animating human
» anatomy. The program says it can take DXF. Is there a 3d version of DXF?
No, dxf is 2d, you need to use IGES, STEP or STL for a polygon file. There are ways to transfer this info from mechanical to artist world through some translator, I'm not sure of the path, hopefully some else knows a path.
What is the name of the program that you are trying to import it into?
Also, what file formats can it open?
» » » This is pretty easy to do.
» » » 1. create a drawing with the 2d views you want
» » » 2. saveas dxf or dwg's are smaller
» » The program I am trying to import into is a 3d program for animating
» human
» » anatomy. The program says it can take DXF. Is there a 3d version of
» DXF?
» What is the name of the program that you are trying to import it into?
» Also, what file formats can it open?
The Program is called Poser and I was told it can take BVH or DXF. I am not actually using the program an associate is taking care of that. I am taking care of the solidworks side.
» » » » This is pretty easy to do.
» » » » 1. create a drawing with the 2d views you want
» » » » 2. saveas dxf or dwg's are smaller
» » » The program I am trying to import into is a 3d program for
» animating
» » human
» » » anatomy. The program says it can take DXF. Is there a 3d version
» of
» » DXF?
» » What is the name of the program that you are trying to import it into?
» » Also, what file formats can it open?
» The Program is called Poser and I was told it can take BVH or DXF. I am
» not actually using the program an associate is taking care of that. I am
» taking care of the solidworks side.
We have some Poser resources here on 3DCADTips.com. I'll look into it further. So you're saying that Poser only imports BVH and DXF and not IGES or STEP or STL? I'll post what I can dig up.
» animating
» » human
» of
» » DXF?
The latest version of Poser can import and export the following file formats:
