Hi
I have used the Rhino cad 6 evaluation download and imported files previously created in dxf format into it as the basis of creating a model that I would like to take through a cam process to a cut model. The model has been previously taken through the process with the use of dxf files, transferred to solid works and cut from there. I had access to a computer running solid works. Simultaneously I am wanting to upgrade from the 3rd party cam program presently used. I am using the basic version of a program which no longer exists due to being sold off to to another company. I had found when working with some previously produced work done. I came across instance where I needed additional programs to find the correct file extension which my very limited cam program will accept. When it came to 3D models the limitations on setting the way the cutting files were prepared to get satisfactory machining results.
Having rushed through the model process using Rhino 6, I would no doubt imagine that the result pictured below would possibly require additional step before taking to cam program. I would appreciate any help and assistance in how to get it into a cam process and what the best program would be use to get a cut product from my endeavours so far.
Regards
Regards
