What do you mean by this? Are you saying that it doesn't pattern in the direction you WANT it to go or that it goes in a different direction than you have TOLD it to go? The first one is easy, there is a toggle that looks like two arrows (flip) that changes direction. If the problem is something different, I will need more information. An image or the file itself would be helpful.When I try to use feature pattern select tool to pattern my hardware, it goes off into the wrong direction.
