Formatting Hole Table Tags
Amando
Can you any way change the text style of the hole table tags. It seems to default to the active dimstyle text. I have set up a new textstyle for this purpose and I was wondering if there is a way to make the hole table use it.
Thanks in advance.
Algernon
Hi Amando,
The hole tags are formatted by a dimension style. You have to use the text style you created as a substyle of the dim style associated with hole tags. You can either create a new dimension style that refers to your new text style , then go to your Object Defaults and map your hole tags to this new style. OR, just assign the text style to the dimension style already being used by hole tags, keep in mind that this will affect all other annotation types that use that same dim style.
