Gear Profile Using Unigraphics
R
ranjith_info
Plz help me in modeling the gear tooth using Unigraphics
the in puts are
NORMAL PITCH 10 D.R
N2 OF TEETH. 105
NORMAL PRESSURE ANGLE 20 Deg
HELIX ANGLE & HAND SPUR
PITCH CIRCLE DIA. 10.500
INVOLUTE BASE CIRCLE DIA. 9.8668
ADDENDUM. 0.072
WHOLE DEPTH. 0.225
ACTUA; BACKLASH. .006/.008
CORRECTION. -0.025
CHECK DISTANCE OVER 5 TEETH 3.5198/3.5188
ROOT DIA. 10.194
FORM OF TEETH INVOLUTE
CLIPER. HEIGHT FROM NORMAL% .050
SETTINGS THICKNESS .1177/.1167
MAX. ERROR IN TOOTH TO TOOTH PITCH ACCURACY 0.0002
MAX. ECCENTRICITY OF PITCH CIRCLE 0.001
TOOTH HEAD EDGES ROUNDBED 0.005
TOOTH FACE EDGES ROUNDBED 0.01
R.P.M 2171 3/7
CENTR DISTANCE 7.153/7.147
FINISH OF TEETH :-
That's quite an amount of information to work with. I guess you may need to pay someone to do it for you rather than asking for help this way. This is a forum, not an extended helpdesk.
Gear profile using NX
If your licence allows you to execute grip routines there is one available called gear_3d that can be used to generate 3D gears. You could try asking your local NX support office, they may be able to help you with a copy.
