Helical Gear
G
gupta_9665
Anyone working/using geartrax?
I need some help to make a model of a helical gear.
Can anyone help me out? I need it urgently.
I tried using the toolbox of solidworks, but that has minimum number of teeth avaiable as 10 but i need 6 and also the dimensions reqd are not matching.
an early help will make me appreciated.
thx and regards
Deepak Gupta
B
brianCAD
Deepak,
A six-tooth gear is going to be grossly distorted in profile and not a practicable working proposition. The software sensibly limits you to a minimum of 10 teeth.
-Brian
G
gupta_9665
helical gear
Thx Mr. Brian.
Well as per specs of the customer, i need a helical gear with 6 teeth only.
though i'm able 2 develop the model in Pro-e but i was not able 2 do the same in Solidworks.
So if anyone using geartrax, i just want to know if gear trax can work in the situation with non standard data.
thx and regards
Deepak Gupta
ttraser
convert
:confused: Why don't you pull up your pro-e model in solidworks. Then you could possibly utilize feature works to rebuild it with features. Just a thought.
G
gupta_9665
helical gear
Thx a lot for the idea,
i had already done that.
but i'm getting wot i exactly need using feature work.
anyhow thx for the idea.
Regards
Deepak Gupta
