How can I save the Product
amnon
I do not know why is it, I save my Product using Save Management option,
I close it and after reopening, Product is not updated.
Al the time I do the same and nothing.
Best regards
Amnon
Could be several things that are causing the problem:
1. If the parts in your assembly have links to other pointed documents, the children parts will always require an update if the parent parts are modified. Make sure you save all the modified parts as well as the product.
2. Are you overwriting the modified parts? If not, you might be saving the modified parts in one folder, but opening the original parts from a different folder.
3. Your Search Order could be wrong, causing the situation in #2.
