How can we lock Pro/E config settings from being changed?
P
PHC77
2)How to lock the access to all these config settings made as per company stds.
-config_init.mc
-condition.mcc
-setconfig.mcc
-check.mch
-start.mcs
constant.mcn
-other text files..
support
We found a response to your question!
Courtesy of our partner site www.MCADCentral.com
responded to by: Speling
If this is connected to all other your post in Cad Administration, than answer is maybe - changing owner of created file - and network administration - I mean that you can allow or deny write - read access to that file - That is on win OS. Similar is for Linux.
Removing options for choosing different types of config settings (when start working on part) is another step - (Deleting all other than wanted). If possible that can be implementer in all other cases.
That is idea. Perhaps maybe someone have some more real experience in this case - similar or different than my general inputs.
Another strategy for solving that problem is teaching people what and where to choose and to implement in theirs work.
Click the following link to see the complete thread on www.MCADCentral.com:
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=29375&TPN=1
Thanks for using the Q&A Board!
support
We found another response to your question!
responded to by: caddie
You can not look access to theese files in ProE. Place the files (all related to ModelCHECK I see...) on a server and give the files/dirs Read-Only access in OS-level.
To make ProE clients look at the files on your server, set the variable "MCDIR" to point to the folder holding the "Config" folder of the modelcheck files. This is how we do it, and it works good! Benefit is you have one central place to edit for all users.
Example:
In a standardinstallation, you could say the setting is as follows:
MCDIR=<...proe_loadpoint>\modchk\text\usascii
http://www.mcadcentral.com/proe/for...um_posts.asp?TID=29375&TPN=1
