How do I clear AutoCad 2006 license file from my computer?
M
mehdi.shatti
also:
I typed commandline on the command prompt to disable the command window.
Then I pressed control+9 to bring it back now everytime I start AutoCad 2006 or ADT 2006 I get a line on the command window as follows:
Autocad menu utilities loaded
Command : COMMANDLINE
command:
Can you tell me how to get rid of the line which says COMMANDLINE?
Thank you,
M. Shatti
Your question about the command line.
We found some discussion about this question in one of the Autodesk Discussion Groups. Here is the complete thread:
http://www.3dcadtips.com/3DCADTips_External.php?site=http://discussion.autodesk.com/thread.jspa?forumID=149&threadID=448690
:) Reply From: None
Date: Jan/11/06 - 13:27 (CST) NEW!
Reply Re: How to get rid of COMMANDLINE?
That wording means you are using the command: line for input. Just means
you turned off DYN.
:) Reply From: C Witt
Date: Jan/11/06 - 13:37 (CST) NEW!
no, it just means you have the commandline active (i use dyn, but have
the CMl active to keep the startup splash screen working.. and
"commandline" still apears). to make it go away, turn off the command line.
:) Reply From: The Marker
Date: Jan/11/06 - 13:47 (CST) NEW!
It's specially done for dummies, than you know it's the commandline.
I hope this helps.
Thanks for asking the Q&A Board!;-)
3DCADTips Q&A Board Support
Do you no longer want to have Acad on the computer?
This is in response to your question title which is different from the content text of this question. That also has a reply in this thread.
Thanks for the question! ;-)
3DCADTips.com Q&A Board Support
More comments about removing Acad license.
Here are some more thread replies from the AutoCAD Discussion Board about this topic:
:) Reply From: Dean SaadallahDate: Jan/12/06 - 03:06 (GMT)
Reply Re: How to clear AutoCAD 2006 licese file from PC?
Uninstall AutoCAD from the user's PC.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
:) Reply From: Laurie ComerfordDate: Jan/12/06 - 08:31 (GMT)
Hi Dean,
I think the only way to really get rid of the licensing off a computer is to
replace the hard disk.
I've had the experience of reformatting the hard disk - reinstalling the
software and finding that my licence was still in place - Clearly there was
information not in the area of the disk accessible to the format command.
Laurie Comerford
CADApps
www.cadapps.com.au
:) Reply From: Ivan L.Date: Jan/12/06 - 14:16 (GMT)
If you do a clean reformat by removing and recreating partitions, the
licence info is gone. But if you use a recovery disk (like Dell's), the
info stays.
"Laurie Comerford" wrote in message
news:[email protected]...
Hi Dean,
Thanks for using the Q&A Board! ;-)
