I want to repeat the small circle eight times in a circular path, through the parametric method so that when I change the size or position one of the holes, all holes follow the changes.
I tried to use "integer" option in f(x) but don't know how to constrain and repeat the small circle so that when I change the values relative to the circle, the eight holes in the solid shape follow the change altogether?
![](https://s6.uupload.ir/files/sketch_ujpj.jpg)
![](https://s6.uupload.ir/files/pad_hrg1.jpg)
![](https://s6.uupload.ir/files/integer_3avt.jpg)
