Inventor 8 - work planes and axis
P
Perdiem856
To All,
How are the work planes, in a assembly, turned off through ALL uses in other assemblies?
for instance, you make a pressure vessel, valves, and piping and make a sub-assembly of these parts. You use work planes to place the valves and piping.
when completed, you turn off planes. now you take this sub-assembly and place it in another assembly - the work planes are now on and visible, WHY
thanks,
PerDiem856
Hello Perdiem856,
We found a related post on the Autodesk discussion boards:
Reply From: Jimmy
If the workplanes live in the part, they have to be turned off in the part.
when you have the plane created as a feature in an assembly.
Hello Perdiem856,
We found another related post on the Autodesk discussion boards:
Reply From: Fonz
In my experience, this happens when you have the plane created as a feature
in an assembly, not in a part, and yes, sometimes no matter you have the
visibility turned off on your assembly, the plane/axis will appear on
further assemblies where you use it. Honestly, at present date I haven't
found the solution for that and I would like to have it.
Such is life.
Best Salutes!
Fonz.
