Make a text around on cilinder face
G
goyo
Hello, my cuestion is:
How I can make a text around on cilinder face, its possible whith solidworks2005?.
can you help me
thanks in advance
goyo
Spain
Sorry for my english :(
support
Good tip
Take a look at this tip!
Text On A Cylinder .
I suggest you make a surface offset from the OD of the cylinder the height you want the text. "Free login required"
#: 874, Author:, Source:Solid Digital Digest (Gurijala: This is for SolidWorks), Submitted by: eDocHelp, Date: 2005-02-20
3DCADTips Support Desk :cool:
bcampbell
Moderator
Text around an axis, like on a tire?
This is done in the sketch mode by inserting text. You can then define a curve to align the text. Your curve should be an arc.
Text wrapped on a surface, like ?.
There's an unwrap command that will flatten the surface, project your text, then wrap it back up. This one is limited in the surfaces that it can unwrap.
G
gupta_9665
make a text around cylinder
well my friend has told u the option of using wrap command and that the easiest one.
even u try the following trick also
well insert a skecth on the plane and write the text u want 2 wrap
the n in extrude command we the option of offset from surface
choose this one
also check the effect on cliking on/off the option transvere surface
regards
Deepak Gupta
