Make plenty of memory available for VX
C
CADMiester
This is from the Tips & Techniques section of the VX CAD/CAM online help.
VX performs memory checks and alerts you if you do not have enough memory or if you are running low on memory. The alert is made if you do not have at least 768 MB of total memory (physical+virtual) when starting VX and if you have less than 128 MB of total memory available while running VX.
If you see this alert, check to see if you have other applications running in the background and close them. This will avoid a possible system failure. VX and your system performance in general will benefit when you make plenty of memory available. See also VX System Requirements.
CADMiester
