Mirroring
Balin
I very recently upgraded to 2007, I am facing problem while mirroring in plan view, I want to mirror a 3d object using a center point of another 3d object, it just does'nt mirror it, it wants to rotate it about the z axis, I never faced the problem in 2006, what should be done to shut this off?
Thanks in advance.
Consider changing the view and see what is happening during mirror command. As the technique for mirroring in 3D as done in 2D only thing is you see orientation with respect to mirroring plane. Most important is see whether Ortho is on and UCS orientation is correct for desired mirroring.
Regards.
