Newbie Question: SectionPlanes every 5cm/Dimensions
s17
Hi!
I plan to build the body of a rc-ship. For this reason I need to do a Cross Section every 5 cm. I used the command "sectionplane". This is what I need but I need it from the front to the rear every 5 cm. After that i want to print only these sectionplanes with the dimensions on it...
How can I do that the fastes and easiest way (every 5 cm, and dimensions)?
Thanks for helping a newbie!
s17
Topographical Survey
Topographical Survey is the study of Earth's surface shape and features.Topographic Survey is used to determine the position of any feature or more generally any point in terms of both a horizontal Coordinate system such as latitude and longitude, and altitude. Identifying (naming) features and recognizing typical landform patterns are also part of the field.
Major Projects – Hydroelectric power, Highways and Bridges Geotechnical Investigation, Topographic and Hydrographic survey, hydropower projects.
