Photoshop to max?
Grjl1970
Is there anyway I can quickly save a file in photshop and have it update in max? As a lot of time is taking up by clicking save as in photoshop and then going back into max to check the render.
Thanks in advance.
You would be able to use a psd file directly in the material slot in max, while you work on the same file in photoshop whatever change you do and save it is updated in max as well, keep in mind psd files can be quite big and use lot of memory. If you want can also record an action to save the file in jpg with one click and assign a function like F2 for instance. Max will update the vieport right away.
Cheers!
