Pocket milling with a radiused endmill
BB_24_1
Help
I am trying to mill a pocket 0.040" deep. I am using a cutter 0.750 dia. with a 0.120 radius on the bottom of the cutter. Is there a way to have the catia manufacturing software do the mathematical calculation for me? My pockets are coming out undersize. I can manually offset the cutter path to the calculated formula, however I was hoping that catia could do it for me. All of the geometry is in the cutter description. Anyone have any suggestions? Thanks!
BB_24_1
Could someone please give any advice on machinning a pocket with a radiused endmill. I am having to manually compensate for the radius on the bottom of the cutter to get my pockets to the right length and width. I am using a 3/4" endmill with a 0.120 radius. I am machining 0.040 deep. I have calculated that my pockets are 0.061 to short in length and width due to the radius. Is there a setting or something in catia manufacturing to have the software compensate for you? Thanks
I'm not an NC specialist, but I thought CATIA did drive the cutting tool directly on the surface. Are you sure you haven't added an offset by mistake?
BB_24_1
I am sure
I am sure. I thought the same thing as well. However upon inspection on the pockets, all pocket came up 0.0406 per side short.
