X
xfaure1
Hello everybody
I try to do a substract between two solids.
I created a DocumentPart.
I copy two parts on this new document.
the first created a model in objDoc.Models.
the second add a Item in objDoc.Constructions.CopyConstructions
and add a item in objDoc.Models(1).Features
So, I process this function :
objDoc.Models.Item(1).BooleanFeatures.Add with goods parameters but it fails!
I don't understand. Does somebody can help me?
thanks a lot
Xavier FAURE
thanks a lot
Xavier FAURE
Code:
Module ModuleVolume
Sub Main()
'Declare the program variables.
Dim objApp As Object = Nothing
Dim objDocs As Object = Nothing
'Turn on error handling.
On Error Resume Next
'Connect to a running instance of Solid Edge.
objApp = GetObject(, "SolidEdge.Application")
If objApp Is Nothing Then
'Error message
MsgBox("The Application is closed. The program is going to open it.")
'Start Solid Edge.
objApp = CreateObject("SolidEdge.Application")
End If
'Turn off error handling.
On Error GoTo 0
'Make the application window visible.
objApp.Visible = True
'Access the Documents collection.
objDocs = objApp.Documents
Dim objDoc As Object
'Find out if any documents are open.
If objDocs.Count = 0 Then
'Add an Part document.
objDoc = objDocs.Add("SolidEdge.PartDocument")
Else
'Access the currently open document.
'MsgBox("Connection of part which is opened")
objDoc = objApp.ActiveDocument
End If
Dim objModel As SolidEdgePart.Model = objDoc.Models(1)
MsgBox("Number of shells ( in Models(1).Body ) : " + objModel.Body.Shells.Count.ToString)
MsgBox("Number of features : " + objModel.Features.Count.ToString)
Dim objConstructions As SolidEdgePart.Constructions = objDoc.Constructions
MsgBox("Number of constuctions : " + objConstructions.Count.ToString)
Dim objCopyConstructions As SolidEdgePart.CopyConstructions = objConstructions.CopyConstructions
MsgBox("Number of CopyConstructions : " + objCopyConstructions.Count.ToString)
Dim objBooleanFeatures As SolidEdgePart.BooleanFeatures = objDoc.Models.Item(1).BooleanFeatures
'The number of solid to do the boolean opertation
Dim NumberOfTools As Integer = 1
'A array which contains these solids
Dim Tools() As Object = {objConstructions.Item(1).Body}
'A member of the BooleanFeatureConstants constant set that specifies the type of Boolean operation to perform.
Dim Operation As SolidEdgePart.BooleanFeatureConstants = SolidEdgePart.BooleanFeatureConstants.seBooleanSubtract
MsgBox("Clic on Ok to process the function")
'Process the boolean fonction
objBooleanFeatures.Add(NumberOfTools, Tools, Operation)
MsgBox("It's Ok")
End Sub
End Module
