RTEXT not updating
Alanna
When I put Rtext in my drawing, its not active while opening the drawing. I can only see one rectangle box. Each time I have to type RTEXT and then it is appearing properly. Can some tell me how to update it while opening the drawing.
Thanx
Hi Alanna,
Add the RTEXT command to your acaddoc.lsp file if you use it all the time or create a file called "acad.rx". Make sure that Explorer displays file extensions for all file types.Open it in notepad. Type the path "C:\Program Files\AutoCAD XXXX\Express\RText.arx" and Save this file inside "C:\Program Files\AutoCAD XXXX" folder.
Cheers!
