Saving changes to styles
Berke
I have changed the styles settings in the styles editor and then saved the .idw file to the template location. The problem is that when I use the template for a new file the settings that I have changed were lost.
Thanks.
Alphonse
You can save in the styles.
Copy the .idw file to the template folder and then open the template and make the changes needed as per your requirement then on the format menu click save styles to style library and select yes for the save to the library option and click ok. Save and close the template file.
Now when you open a new document using the updated template file the changes to the styles will be reflected.
Hope this helps
