Search.pro
Mark Parsons
I have set up my search_path_file in the config.pro file and set my directories in the search.pro file. However when I open an assy it still opens with the resolve error message.
I am using Wildfire 3.0 and have put the config file in the text folder. Every other aspect of the config file is working correctly.
Does anybody have any ideas?
I have attached my files if anybody can point out any error.
  • search.zip
street_preacher
Your search.pro file should contain paths and comments (delimited with "!" as I am sure you are aware of). You'll want to eliminate "search_path " and the quotation marks. I am curious to know if this fixes your problem. I typically don't use spaces in paths due the problems it causes with our database UI. I don't recall if this is a problem with ProE or not.
sen74us
PLEASE CHECK YOUR CORRECT SEARCH PATH:
!==== FILE SEARCH PATHS ====
search_path C:\Documents and Settings\mparsons\My Documents\Pro-E\Indica Dicor CVT
search_path C:\Documents and Settings\mparsons\My Documents\Pro-E\Parts_library
search_path C:\Documents and Settings\mparsons\My Documents\Pro-E\CVT bits
Thanks & Regards,
Senthil Kumar P
