A
aval_29
how can i make sure that may sketches are constraints? thanks
We found this comment of the Autodesk discussion boards. It may help answer your question.support said:Use the Auto Dimension tool. If it reports that zero constraints/dimensions are required, then your sketch is fully constrained.
We found this comment of the Autodesk discussion boards. It may help answer your question.support said:That is what I do when I am not sure. You can't always trust the color.
We found this comment of the Autodesk discussion boards. It may help answer your question.support said:Good point Kent - There are times when the colour will show fully constrained but when you exit the sketch and go back in there may be a green line. I should have thought of that.
We found this comment of the Autodesk discussion boards. It may help answer your question.support said:There are other times that the color does not change until you try to "pull" on the line or point. Then it changes color. Such simple things...
support said:We found this comment of the Autodesk discussion boards. It may help answer your question.
Reply From: Brian R. Iwaskewycz
Date: Mar/31/06 - 14:28 (CST) NEW!
Brian R. Iwaskewycz
CAD Systems Manager
Core Furnace Systems
Thanks.
3DCADTips Support Desk![]()
