Is there a way to view velocities at particular locations? At the moment is shows the velocity profile of air then you as a user are forced to interpolate based upon the color coded velocity bar. The only finite value you know is the max velocity which isn't helpful for what I'm doing. I either need to be able to find velocities and particular points or I need to be able to average the velocities at the selected outlet. I currently don't know if floxpress has this capability or if I just don't know how to use it. Either way, any help in figuring this out would be much appreciated.
I'm using Solidworks 2010:
